Those with the SLP TCS Logic Module -> IN
I'm thinking of buying the SLP TCS Logic Module, and my current understanding is that it turns the Traction Control OFF at startup. To quote their website: I don't want another switch. Can I use the same factory "ASR" button on my Camaro's dash to turn it on?
Thanks in advance!
It's "off" until you turn it "on" with a manual switch on your car's dash or console.
Thanks in advance!
Awesome. Thanks guys.
Forgot to turn it off one night at the strip and stalled a burnout attempt.
I'm willing to spend a little $$ to make sure that doesn't happen again.
As mentioned above, you pull off the plastic cover or plate, whatever you want to call it, with the TCS switch on it and the module plugs into the harness behind there. Takes all of 5 minutes to install and program.
