tsp 231/237 & Comp Cam 231/237
Old 01-02-2006, 09:24 PM
cowboysfan's Avatar
Default tsp 231/237 & Comp Cam 231/237
what are the differences of these two cams? if any! I noticed tsp sells them but, it is a Comp Cam. just curiuos if any difference .
you guys running them what kind of rwhp are ya'll making? and on 1/4 mile runs wahat ya'll clocking or have clocked? on slicks or street tires? thanks guys
fuerzaws6
Old 01-02-2006, 09:41 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
TSP 231/237 uses Lunati lobes, much less aggressive than the Comp XE-R lobes.
The Lunati lobes come on real hard at the upper mid/ high rev range, with some sacrifice to low end.
The Lunati lobes are very valvetrain friendly. You can use Comp 918's with them no problem.
Difference of the TSP 231/237 from .050 to .006 is 58/62 (intake/exhaust), far from the 49 range of XE-R, and more like XE (or even lazier still).
The Comp grind may exhibit more drivability and more low end while retaining the upper end at the expense of valvetrain stress.
Old 01-02-2006, 09:58 PM
REDWS6ROCKET's Avatar
you to run the tsp 231/237 very nice cam with a very noticeable lope. it was very easy on valvetrain.
Old 01-04-2006, 02:12 AM
cowboysfan's Avatar
so do i need to worry about stressing the valve train w/ Comp Cam or will it require for me to change springs sooner ?
thanks
fuerzaws6
Old 01-04-2006, 09:31 AM
!LS1 11 Second Club
Just check a couple of your springs after 18 months or so to see how they're doing.
Old 01-08-2006, 02:44 AM
cowboysfan's Avatar
just got my cam from comp cams. can somebody post or pm me tsp 231/237 cam card so I can compare it w/ Comp cam card I got w cam? want to see the difference.
thanks
furzaws6
Old 01-08-2006, 09:18 AM
!LS1 11 Second Club
JRP's stick has one on file.
http://ourworld.cs.com/jrp98ls1/camcard_231_237.jpg
Old 01-08-2006, 03:55 PM
cowboysfan's Avatar
Originally Posted by SouthFL.02.SS
thanks. this ealy helps.
fuerzaws6
Quick Reply: tsp 231/237 & Comp Cam 231/237
