have a question about my motor.
back a couple of months ago i thought my motor in my 98 Z28 let go. (the stock motor).here is the oringinal thread:
https://ls1tech.com/forums/racer-s-lounge/418735-well-my-motor-let-go.html
i suspected a dropped valve or collapsed lifter. i pulled the top end of the motor off all the way down to the shortblock while in the car. i didnt find anyhting wrong in the heads and all the lifters pump up like they are supposed too. well toady i got ready to pull out the short block today and found my problem. 1 torque converter bolt missing, 2 i undid with my fingers, and 1 tight. no sign of lock tight. this is an after market stall too.
question 1. what is the likley hood of having engine damage from this? i havent pulled the shortblock yet. i figure the flywheel is jacked. i can rortate the shortblock with ease and it has no apparent snags. smooth a silk.
question 2. what about the tranny? any negitive effects this could have on the tranny?
thanks
thanks
I'm going to say the engine is just fine. reason being, when a stock 10 bolt for example breaks and the axles lock, the tranny usually dies with it but the engine is usually fine. Also those loose bolts would have meant the engine had no real physical connection to the transmission. I think you got pretty damn lucky, perhaps the stall is ok too.
