dirty MAF = running to lean?
Old 01-05-2006, 10:41 PM
TAwhore's Avatar
Default dirty MAF = running to lean?
would a dirty MAF throw codes that state that the car is running to lean?
Old 01-06-2006, 06:29 AM
Billiumss's Avatar
Yes it is possible. Did you recently install or clean a K&N filter?
I "fixed" a few LS1 cars that had a dirty MAF. It would knock/ping at WOT, cleaned MAF and the problem went away.
Old 01-06-2006, 10:17 AM
dug
dug's Avatar
How do you clean them?
Old 01-06-2006, 10:28 AM
tc3
tc3's Avatar
get a Q-tip and put some alcohol on it. The more % of alcohol the better. i use isopropyl alcohol which is 70% alcohol. gently(extremely) wipe the sensors with the very tip of the q-tip.
i have done it this way many times and have never had any problems. The higher % of alcohol makes it evaporate almost instantly
Old 01-06-2006, 10:51 AM
dug
dug's Avatar
thanks, my car runs a lil lean. Hopefully this will fattn it up.
Old 01-06-2006, 10:52 AM
RedHardSupra's Avatar
graph MAF signal vs MAF freq and you'll see how noisy the system is. then clean the maf/air filter and scan/graph again, and you'll see the difference in how spread the points are from the main trend. or if you're more mathematically inclined, do some basic stats on it and you'll see how your standard deviation is.
you have no idea how much simpler the tuning will be (if you're using maf of course) once you have a clean signal.
Quick Reply: dirty MAF = running to lean?
