How much noise does a cogged belt add?
I will upgrade from my V-2 SQ S-trim to the V-2 SQ T-trim sometime in the spring. I'm thinking of changing to the cogged belt to eliminate the slippage issue. Is the cog a lot noisier than an 8-rib? Anything else I should be thinking of? This is mainly a street car.
Jim
Jim
I really have no clue how that could be true. Think about it the cam belts on every car thhat has a belt, not a chain, isnt noisy at all. And it takes quite a bit of power to turn a cam. I have heard people say taht they do make noise bt how is that possible? If im wrong please educate me as im interested.
John
John
My guess would be for the same reason that cam gears make noise...The friction of the gears even though it is a rubber belt...Multiply that by a ton of rpms I bet it could get very loud...Have you ever seen a roots blower on a deuce coupe or something??? they whine noticably at idle...
http://home.comcast.net/~jsbird1998/cog.mov
Link for my old Procharged Cog set up. It was truely badass, too bad the belt wouldn't stay together.
I understand that the cog belt makes noise by having to force air out of the cogged pulley as it places each individual cog. Multiply that by the speed of the motor and you get a high-pitched whine.
I just wondered how it was in comparison to a ribbed belt and also compared to a blower with straight-cut gears, like most Vortechs.
Jim
Jim
Right at the 1:29 mark on your vid, is that your blow off whistling as your reving it? That just sounds truly bad ***.
