what rust preventative did you use?
Originally Posted by ninobrn99
As the title says, what rust preventative did you use on your 12 bolt or 9" housing and where did you get it??
POR-15 no doubt! All you need is the starter kit to paint the 12-bolt and you will have some left over afterwards. Amazing stuff that will keep the rear looking new forever probably.
http://www.por15.com/PRODUCTS/PRIMER...7/Default.aspx
