CR = boost
Old 01-12-2006, 07:00 AM
fastlt1's Avatar
Default CR = boost
What compression ratio to run what amount of boost? A chart would be nice. Something like. CR 10.5 IC 7lbs non-IC 5lbs
Mostly want to know what CR is needed to run D1SC at 12lbs on lt1 on pump gas no meth at full timing.
Old 01-12-2006, 06:24 PM
fastlt1's Avatar
Any ideas?
Old 01-12-2006, 07:50 PM
BrandonDrecksage's Avatar
its all in the tune. you could run higher psi with a great tune, but a shitty tune and you'll have to run less.
Old 01-12-2006, 08:38 PM
fastlt1's Avatar
I found this.
Correct Compression Ratio = FCR minus [(altitude/1000) x 0.2]
Compression Boost (in pounds per square inch)
Ratio
2 4 6 8 10 12 14 16 18 20 22 25
6.5:1 7.4 8.3 9.2 10.0 10.9 11.8 12.7 13.6 14.5 15.3 16.21 17.0
7.0:1 8.0 8.9 9.9 10.8 11.8 12.7 13.6 14.5 15.3 16.2 17.0 17.9
7.5:1 8.5 9.5 10.6 11.6 12.6 13.6 14.6 15.7 16.7 17.8 18.6 19.5
8.0:1 9.1 10.2 11.3 12.4 13.4 14.5 15.6 16.7 17.8 18.9 19.8 20.9
8.5:1 9.7 10.8 12.0 13.1 14.3 15.4 16.6 17.8 18.9 19.8 20.9 21.9
9.0:1 10.2 11.4 12.7 13.9 15.1 16.3 17.6 18.8 20.0 21.2 22.4 23.6
9.5:1 10.8 12.1 13.4 14.7 16.0 17.3 18.5 19.8 21.1 22.4 23.6 24.8
10.0:1 11.4 12.7 14.1 15.4 16.8 18.2 19.5 20.9 22.2 23.6 24.8 26.0
10.5:1 11.9 13.4 14.8 16.2 17.6 19.1 20.5 21.9 23.4 24.8 26.2 27.6
11.0:1 12.5 14.0 15.5 17.0 18.5 20.0 21.5 22.9 24.5 26.0 27.5 28.9
Quick Reply: CR = boost
