Work in progress... 56k users beware!
Old Jan 12, 2006 | 10:15 AM
Blown383's Avatar
Default Work in progress... 56k users beware!
Welp finally got the motor out...here are some pics.
Really wasn't hard at all.... Now that I've dropped the motor I can't see it taking more than 4 hours if you have the proper tools and plan everything out.
The only thing that caught me off guard was the damn battery cables that got snagged. Out of the bottom is the ONLY way to go. Soooo easy.
As you can see in that picture the tranny is just covered in gunk from the old intake leak. Anyone know a good way of cleaning it? I was planning on soaking the tranny with degreaser and using a pressure washer to hose everything off.
I didn't have access to a trunk so I decided on some ingenuity...
Then I realized it was tooo freaking big and probably not too safe to have hanging out of the truck :shock: Soo........
I used a blanket and a boogie board to keep the engine from denting and scratching everything.
I also had to use a smaller jack to get the cherry picker legs to slide underneath the car, after slowly releasing the jack down and one swift kick it landed into the passenger side of the car. Its also obvious that I had to remove te passenger side seat to get it to fit.
The engine was soo heavy that it actually stressed the frame of the car, the paint on pillar between the front door and back door cracked all over the place.
When I got to the shop the guy didn't believe me when I told him I have a long block in the passenger side of the car. He kinda just scratched his head and asked 3 of his employees to tackle the job of removing the engine. 3 employees, 2 chains, and 1 fork lift later the engine came out of the car.
Engine guy said that it'll take roughly 2 weeks to get the long block back however there is a bunch of minor custom stuff thats needed for the engine since its going to be a blown stroker motor.
I still need to iron out the fuel system and the cam.
So far I gathered:
*Racetronix single fuel pump & harness
*83lbs Siemens injectors
*MSD boost-a-pump
*Aeromotive APFR
I believe that setup "might" be enough for a blown 383 pushing 15+ psi... however its seems that I may have to step up to a dual in tank setup. If thats the case I may have the Racetronix kit up for sale.
I'll keep you guys updated.
-B
P.S. I plan on using a truck to pick up the rebuilt engine.
P.P.S - Special thanks goes out to Nick Steel, Brian Blitz, Jared (for lending me the hoist), and Mike Leaf for support and advice.
Old Jan 12, 2006 | 10:31 AM
RyanJ's Avatar
SSU Moderator
Dropping the motor and all that stuff is neat...but carrying the motor in a ******* Accord is super-bad-***! ...And in the front seat! NOICE!
Old Jan 12, 2006 | 10:37 AM
FastKat's Avatar
When I saw that first pic of it going in the front seat I thought you were just joking.....
That really is funny!
Old Jan 12, 2006 | 10:41 AM
JL ws-6's Avatar
Race your car!
You are a nut with the motor in the passengers seat like that.... hands down the funiest thing I think I've seen in a long time
Should be a mean setup though when you are done. Not sure about the fuel pump setup.. you may want to put that racetronix up for sale before you even try it. 83 lb inj. is a BIG injector, and is gonna need alot of pump I'd think.. probably at least 400 gpm of fuel flow to keep the pressure up in higher rpm's. You're probably looking at dual pumps... I'd rather do that and be safe, then take a chance with a new motor.
LoPeY's Avatar
That's awesome! Way to get the job done!
Old Jan 12, 2006 | 10:43 AM
buschman's Avatar
I once carried my old Dodge FWD tranny in the backseat of a friends Civic, but you got me beat by a mile. You need to take pictures of those stress cracks in the paint. That's hilarious.
Honda = Haulin
Mike
Old Jan 12, 2006 | 11:22 AM
kp's Avatar
kp
awesome
Old Jan 12, 2006 | 12:09 PM
Hugger Z's Avatar
Wow, and I thought I had seen it all. Never seen an engine riding shotgun!
Back in college the neighbor to the house we rented had an engine pulling chain hanging from a huge tree and used to pull motors and service cars in his driveway. Saw a lot of weird things there, but never carrying an engine inside a car.
Sounds like you will have a nice monster once it's all complete. Good luck.
Old Jan 12, 2006 | 12:14 PM
NA$TY-TA's Avatar
Damn photobucket.... work blocks them......
sounds pretty mean though... ill have to wait till im ff so i can see the civic pic.
Old Jan 12, 2006 | 12:28 PM
BLWN1's Avatar
Can 't you rent a Uhaul in town for like 20.00? Its a thought, but damn those pics are priceless...
Old Jan 12, 2006 | 12:34 PM
SSilverSSurfer's Avatar
lol...its just honda...at least its good for something besides racking millions of miles without breaking down
Old Jan 12, 2006 | 12:35 PM
koolaid_kid's Avatar
I bet you blew the engine guy's mind when he saw the motor sitting there.
So, if it will fit sideways in the front seat, I wonder about under the hood....
Old Jan 12, 2006 | 12:45 PM
777's Avatar
777
Probably one of the funnier things I have seen. Props to you for fitting that beast in the car.
Old Jan 12, 2006 | 01:49 PM
Blackbird's Avatar
How did you lift the car up?
From the pics I can't figure out how you did it.
Old Jan 12, 2006 | 02:28 PM
buschman's Avatar
You know I was wondering the same thing. The only thing I can think of is one of those in-ground center piston lifts the dealerships use. But that is clearly a home garage and I have never seen an inground lift in a home garage. (although it would be beyond pimp!) At first I thought it was two different garages cause in the first pic the garage door makes the roof look a lot shorter than it does in the second pic. but if you look at the background it's definitely the same garage.
I'm curious too how you got the Camaro that high in the air? It's like magic, yo!
BTW: Brake cleaner would probably work well on cleaning that tranny up.
Mike
Old Jan 12, 2006 | 02:37 PM
ABeasst's Avatar
looks like he used the engine hoist to lift the car up with the tow strap. Then if you look in the 2nd pic on the driver side he put a bunch of wood and a jack stand on top of that to hold it, and on the passenger a jack with a 2x4 to hold it up.
Old Jan 12, 2006 | 02:44 PM
buschman's Avatar
Crap I see it now. The jackstand on the pile of wood is bad enough. But a 2X4 lenthwise on a 3 ton hydraulic jack. That's crazy! But no more crazy than an LT1 riding shotgun, I suppose.
Mike
Old Jan 12, 2006 | 07:47 PM
RDeputy150's Avatar
Necessity is the mother of invention. Nicely done.
Good luck on the rest of your project.
Old Jan 12, 2006 | 07:53 PM
Superman09's Avatar
LS1Tech Sponsor
Hahahahahaa, the longblock called out shotty. haha thats sweet. Good luck with the build up and cant wait to see the new numbers!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 12, 2006 | 07:54 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
At first I thought someone had photoshopped it......I guess not..?? WOW O WOW.
