LS1 vs LS6 intake.......
How much rwhp should I see if I swap out my LS1 intake for an LS6? I've heard you don't see much gain.................like around 5rwhp!
Originally Posted by frisky2101
you probably won't see a lot at first but the more you do to your car the more you will see I.E. cam /heads
Any opinions???
I would go with the LSX if you the extra dough think the intake and TB set up is aroud 1200 ish
I hear you there, still got the stock heads on mine, got the cam but I want to go bigger, Was planning on get the LS6 intake but decided to save my $$$ for the 90/90 instead
No I think it might be a bit to small this is the add from TR
99-TR230/224-111 Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars . Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended
TR made 410rwhp /390 torque
with this setup
This dyno graph is of a 1999 LS1 TransAM with Thunder Racing 230/224, 111 lsa Camshaft with stock cylinder heads. Other mods include Grotyohann Long Tube headers, Whisper Lid, LS6 intake manifold, Thunder Racing ported throttle body, ASP Pulley, 12 bolt rear end w/ 4.30 gears and custom computer tuning. The "before" graph shown are with the same bolt-on modifications. The only things that were changed were the camshaft and the y-pipe was replaced with 6" collector extensions for dyno and track use.
with this setup
with this setup
with this setup
Oh wait.....you have mid length headers! Dude, IMO you would benefit at least 10 more rwhp from LT's over the ones you got! I'm not positive though! I just heard that if your not running LT's your wasting your money.
