GMPP ls6 cnc head flow #'s
Well search is not working. Does anyone have the flow #'s for the GMPP cnc'd LS6 heads handy. I am interested in comparing them to the current heads offered by a couple of sponsers.
Thanks!
Thanks!
LPE says------------- Local machine says
-----Int.- Exh. -----------Intake--Exhaust
200 150 117 -------------144.87--102.48
300 225 168--------------202.79--139.75
400 273 202--------------260.35--177.26
450 285 210-------------------------------
500 291 217--------------290.49--199.93
550 304 221-------------------------------
600 311 222--------------301.70--215.35
700 -----------------------292.53--222.35
There they are.
Heres the thread if you feel like looking.
https://ls1tech.com/forums/generation-iii-internal-engine/312456-pe-ls6-flow-numbers-local-bench.html
Unless your talking about different heads which you might be.
However I think LPE and the GMPP heads are the same.
If I am wrong however which wouldn't be the first time then at least you have the flow numbers for the LPE heads.
There they are.
from SDPC's catalog..
.100 66 55
.200 140 112
.300 214 163
.400 261 192
.500 292 213
.550 296 214
.600 288 218
for the 60cc version
awesome mid lift numbers. I was thinking about getting a set myself, but probably will go the budget route... Texas Speed is offering some ported LS6 heads that somewhat close to these... but $850 a pair!
https://ls1tech.com/forums/generation-iii-internal-engine/435738-prc-ls2-ls6-new-port-now-complete.html
.200 140 112
.300 214 163
.400 261 192
.500 292 213
.550 296 214
.600 288 218
Originally Posted by rck329
.100 66 55
.200 140 112
.300 214 163
.400 261 192
.500 292 213
.550 296 214
.600 288 218
https://ls1tech.com/forums/showthread.php?t=435738
.200 140 112
.300 214 163
.400 261 192
.500 292 213
.550 296 214
.600 288 218
know if this is because of revised #'s or a different porter is doing the heads.
Originally Posted by jbuckweiser
I've noticed that the flow numbers are lower than earlier GMPP heads. I don't
The SDPC catalog says their numbers are from their own flow testing on an SF 1020.
Originally Posted by jrp
dont forget the port volumes are 240 - 250cc.
Any opinions as to how the gmpp heads compare to the new Patriot LS6 cnc, the Livernois CNC LS6 or the PRC LS6 heads sold by Texas Speed??
All of these heads are half of the cost of the GMPP heads
Jerami is right. The GMPP heads have a intake runner volume of around 246cc. We have our 243 CNC ported castings availabe for as low as $845.00 per pair. Our intake runner volume will be 227cc +/- and here are some flow numbers fron 1020 Superflow on a 3.905" bore, using a clay radius, with 2.00"/1.55" valves:
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
Below are the different versions we have of these heads:
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be bare with no valvetrain.
Pricing is $845.00 per pair, no exchange.
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. Heads will be assembled with OEM 2.00"/1.55" valves and LS6 springs. They are the perfect head for a budget build. The combustion chambers will be 64cc and extra milling is available at no extra charge.
Pricing is $865.00 per pair, assembled no exchange.
New Factory 243 Patriot CNC ported heads with Ferrea valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves. No springs will come with this particular option.
Pricing is $1,075.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with OEM valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with OEM (non-sodium) valves along with our orginal Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, and Machined spring Bases.
Pricing is $1,095.00 per pair assembled, no exchange.
New Factory 243 Patriot CNC ported Stage II assembled heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves, Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, Machined spring Bases, and Bronze Valve Guides. These heads are the best buy for the money. They are assembled with the highest quality parts at the best price available. When comparing apples to apples, you will find that these heads are simply the best value on the market.
Pricing is $1,395.00 per pair assembled, no exchange.
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
