Carbed 383
Carbed 383
I almost have my Carbed 383 Finished an i was wondering if anyone had a Detailed List of what had to been done when putting it in the car to make it work. I know the gauges but what else i know you have to do something with the fuel system are you just reglating it down are goin a differnt direction.
Thanks Matt
Also the search is down i know this has been beat to death
Thanks Matt
I run a Holley elec FP,factory alt,ps,and bracket,Lt headers,Z28 rad and dual fan setup,ps fluid reservoir from a 95 cr-vic mounted on pass inner feder(looks factory). Drops in like a standard SBC. lemme know if any other questions.
I am puttin this in a 4th gen i was wondering if you could keep the stock gauges somehow and if you have to put a differnt fuel pump in or could it be Regulated down enough to use the stock pump
Yea,if you or someone you know is crafty with wiring you can keep the gauges. As far as the FI fuel pump,no,it makes too much psi to drop down w/a regulator.Just remove it from the tank and run a tube/hose to a sock from a carb'd car's sender,and an external FP.
