A couple of questions.......
Wazzup guys, I have a couple of questions some of you may be able to help me with. First, is there a way to tell the difference between a LS1 intake
and an LS6? Also my car has the SLP tags on the doors, does this mean
I have some or all the SLP options? Thx in advance!!
https://ls1tech.com/forums/showthrea...ls1+intake+ls6 This Link should clear up all of your questions in reguards to wether or not you have an LS6 intake....the major points are without taking it off of the block LS6 intakes do not have EGR's.....if your intake has EGR then it is not a true LS6 intake, although that link says that some LS6 intakes were ordered with EGR this would be vary rare indeed. Also in respect to your question reguarding your SLP badges... the only true tell tail way to find out whether or not you truely have all SLP options is to find the RPO code list on your driver side door and figure out what all options you have installed from the factory and then compare that to what codes the SLP option includes....hope this helps you out
seth
seth
Originally Posted by Lithium
Could not of said it any better.
