Pics of Center Mounted GMMG?
Old Jan 13, 2006 | 11:46 AM
GoldenBird's Avatar
Default Pics of Center Mounted GMMG?
I've only seen this done a couple times and found pics of one car. Searching for "CME" and "GMMG" came back fruitless. If anyone has this done or has any good pics please post and specify which rear valance and tips you are running. SLP sells a whole kit, but I'd much rather have the best of both worlds in terms of looks and sound. The other issue is that I've seen at least two different rear valances used, plus I'm not sure how the GMMG tips look right next to each other since that's obviously not how they where designed to be mounted, so I'm not really sure what my options are in that regard. Thanks.
Old Jan 13, 2006 | 01:30 PM
LawmanSS's Avatar
I adapted the SLP "OEM-style" dual tip CME valance and tips to my GMMG. You need the rear valance, right/left mandrel bent elbows, and tip assembly. Here's a pic:
https://ls1tech.com/forums/attachmen...chmentid=37981
The parts you'll need from SLP:
http://www.slponline.com/view_product.asp?P=10758K
http://www.slponline.com/view_product.asp?P=10761
http://www.slponline.com/view_product.asp?P=10863
http://www.slponline.com/view_product.asp?P=10864
Note: I also had to do some additional fabrication and welding to get my tips lined up to my satisfaction, but most others have not...FWIW.
Old Jan 14, 2006 | 01:57 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Thats badass Lawman
Definitely the ultimate and best looking setup.
Old Jan 14, 2006 | 02:51 PM
Scotty-Z's Avatar
Yeah, that is the ultimate setup.
Old Jan 14, 2006 | 06:43 PM
LawmanSS's Avatar
Thanks.
Old Jan 15, 2006 | 06:38 PM
6SSPEED's Avatar
Old Jan 15, 2006 | 10:11 PM
00SLPSS's Avatar
awesome cars guys.
Old Jan 15, 2006 | 11:12 PM
SSilverSSurfer's Avatar
bad *** bet it sounds good
