Radiator and cooling on an LS1
Old 01-18-2006, 07:43 AM
BadROC's Avatar
Default Radiator and cooling on an LS1
Hi guys, i'm in the process of doing an LS1 swap on my 3rd gen iroc i just need alittle light shed on a few things. First i have an aftermarket 31x19 aluminum radiator in my car now, on an ls1 radiator (6spd car) are there any sensor that are on it, coolant temp or anything of sorts, if so can it be relocated anywhere else so that i could keep my big radiator? OR would i be better off sellign the aftemarket one and using the stock ls1 radiator? I suppose i could have bungs welded onto my big radiator if need be..
Thanks Mike
Old 01-19-2006, 09:54 PM
WILWAXU's Avatar
Depending on the year of your wiring harness there might be a coolant level sensor. If your harness uses one, I'd suggest not using it. Newer F-bodies (~'00-'02) didn't use them.
