will a truck oil pan fit in an f-body?
Old 01-19-2006, 11:31 AM
Paulz2820's Avatar
Default will a truck oil pan fit in an f-body?
will i have any problems with it as far the motor going into the car...it appears as if it will work. thanks
Old 01-19-2006, 12:03 PM
King James's Avatar
It will fit but it will be a very tight fight going over the K-member. The biggest problem would the the lack of ground clearance. Unless its a track only car that will never pull the front wheels off the ground I would highly suggest NOT using the truck pan.
Old 01-22-2006, 01:46 AM
TJ
TJ's Avatar
i could push down on my fender and the pan would bottom out.
i pulled the motor back out after a test fit and ordered a f body pan.
