Underdrive pulley and charging
I would leave the stock pulley on. I have the overdrive alt pulley and it acts fine with no electrical loads on it at idle. But I have to keep the rpm above 1000 to charge above 13V when the a/c is on, and head lights are on. Not a big deal, and it is not going to drain your battery while you sit at a stop light. If I did it over again I would go underdrive alt or just stock alt. I think the ASP web site says what RPM will charge like normal, with each set up.
The stock idle for an M6 car is 800rpm. The stock idle for an A4 car is 550rpm. They both have the same alternator. The majority of underdrive pulleys/dampers slow down the accessories by 25%. Do the math, you will be fine.
