Strange 12 bolt vs. Billingsley fab 9 weight results.
LS1Tech Sponsor
Strange 12-bolt with 33 spline axles, spool, aluminum cover, Spohn Drag Bar Aerospace drag brakes, no fluids, 5/8" studs with lugs and spacers.
VS.
Billingsley Fab 9, 40 spline gun drilled, star flanged axles, aluminum center section, billet pinion support, billet yoke, lightened spool, pro gear, Billingsley anti-roll bar, Strange drag brakes, moser torque arm mount no fluid, 5/8" studs with lugs and spacers.
12-bolt- 240#
Fab 9 - 200#
These weights are as per my $7.95 walmart bathroom scale.
belive it or not.
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
A 12 bolt would probably lose 40lbs with a set of gun drilled star flanged axles, a lightened spool, and a lightened pro gear.
40lbs just doesn't seem like much for a rearend that costs double what the 240 pounder does IMO. Although it is probably a MUCH stronger piece. For a hardcore car, there are more advantages than the weight loss, but I just thought it'd be a bigger difference.
Shawn
Shawn
Sweet Cheeks
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
Also, a steel spool in the 12 bolt versus an aluminum in the 9".
I believe spool for spool, brakes for brakes, and rollbar to rollbar, the 12 bolt will be lighter. IMHO
Good info Brady.
Retired Street Racer
Originally Posted by Dear John
Well, the 12 bolt had a HEAVY Spohn Drag bar opposed to a Jay's light bar, and the strange brakes are lighter than the Aerospaces, both advantages toward the fabbed 9".
Good info Brady.
Sweet Cheeks
Originally Posted by Ben R
The 9" is far superior in terms of gear selection and parts availabilty should you break anything at the track.
True. However, I feel weight is the main subject.
LS1Tech Sponsor
FWIW, the aerospace and the strange rear brakes probably weigh nearly the same. The 9" has a steel spool in it too (although lightened)
I don't know what the spohn sway bar weighs, but it looks beefy. The Billingsley anti-roll bar is pretty lightweight (But I broke my last one) I may get ambitious and pull the spohn bar off and weigh it.
__________________
2016 Z07 Carbon
2016 Z07 Carbon
LS1Tech Sponsor
The problem guys is you are comparing apples and oranges. The 9" Ford race ready and a 12 bolt race ready are worlds apart.
In a lite weight medium hp car I would definitely run a 12 bolt. In a car that makes HP needs a 9". You need to compare 9" to 9" and 12 bolt to 12 bolt.
LS1Tech Sponsor
I agree, but the question came about in this thread: https://ls1tech.com/forums/drag-racing-tech/267733-billingsley-fab-9-weights-broken-down.html
__________________
2016 Z07 Carbon
2016 Z07 Carbon
Does BBC /glide with brake and 2 stages of nitrous = 9" or 12 bolt?
I am new to this, but don't want to make a COSTLY mistake...Thanks
LS1Tech Sponsor
Originally Posted by jshiver
what would you consider a "medium" hp car?
