Strange 12 bolt vs. Billingsley fab 9 weight results.
LS1Tech Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Strange 12-bolt with 33 spline axles, spool, aluminum cover, Spohn Drag Bar Aerospace drag brakes, no fluids, 5/8" studs with lugs and spacers.
VS.
Billingsley Fab 9, 40 spline gun drilled, star flanged axles, aluminum center section, billet pinion support, billet yoke, lightened spool, pro gear, Billingsley anti-roll bar, Strange drag brakes, moser torque arm mount no fluid, 5/8" studs with lugs and spacers.
12-bolt- 240#
Fab 9 - 200#
These weights are as per my $7.95 walmart bathroom scale.
belive it or not.
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
A 12 bolt would probably lose 40lbs with a set of gun drilled star flanged axles, a lightened spool, and a lightened pro gear.
40lbs just doesn't seem like much for a rearend that costs double what the 240 pounder does IMO. Although it is probably a MUCH stronger piece. For a hardcore car, there are more advantages than the weight loss, but I just thought it'd be a bigger difference.
Shawn
Shawn
Sweet Cheeks
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
VS.
12-bolt- 240#
Fab 9 - 200#
belive it or not.
Also, a steel spool in the 12 bolt versus an aluminum in the 9".
I believe spool for spool, brakes for brakes, and rollbar to rollbar, the 12 bolt will be lighter. IMHO
Good info Brady.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Retired Street Racer
Well, the 12 bolt had a HEAVY Spohn Drag bar opposed to a Jay's light bar, and the strange brakes are lighter than the Aerospaces, both advantages toward the fabbed 9".
Good info Brady.
Sweet Cheeks
Originally Posted by Ben R
The 9" is far superior in terms of gear selection and parts availabilty should you break anything at the track.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
True. However, I feel weight is the main subject. ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
LS1Tech Sponsor
FWIW, the aerospace and the strange rear brakes probably weigh nearly the same. The 9" has a steel spool in it too (although lightened)
I don't know what the spohn sway bar weighs, but it looks beefy. The Billingsley anti-roll bar is pretty lightweight (But I broke my last one) I may get ambitious and pull the spohn bar off and weigh it.
__________________
2016 Z07 Carbon
2016 Z07 Carbon
LS1Tech Sponsor
The problem guys is you are comparing apples and oranges. The 9" Ford race ready and a 12 bolt race ready are worlds apart.
In a lite weight medium hp car I would definitely run a 12 bolt. In a car that makes HP needs a 9". You need to compare 9" to 9" and 12 bolt to 12 bolt.
LS1Tech Sponsor
I agree, but the question came about in this thread: https://ls1tech.com/forums/drag-racing-tech/267733-billingsley-fab-9-weights-broken-down.html
__________________
2016 Z07 Carbon
2016 Z07 Carbon
Does BBC /glide with brake and 2 stages of nitrous = 9" or 12 bolt?
I am new to this, but don't want to make a COSTLY mistake...Thanks
LS1Tech Sponsor
Originally Posted by jshiver
what would you consider a "medium" hp car?
