Drag Racing Tech
mad man's rack (no pun)
Old 01-23-2006, 10:32 PM
7 Second Club
ty_ty13's Avatar
Default mad man's rack (no pun)
when using mad mans rack on a BMR k member do you have to get the pinto an manual rack setup or will it work with the standard power steering rack?
i ask because on the mad man rack it says it will work with stock Kmember.
Old 01-24-2006, 12:15 AM
GueSS Who's Avatar
His rack will work with any K-member that will except a stock rack. His is based off the stock setup. It will fit on a BMR. I have Madman rack with all BMR upfront. You do have to weld the tab to the K-member but other then that it is a bolt on peice that saves alot of weight.
Old 01-24-2006, 08:11 AM
7 Second Club
ty_ty13's Avatar
what would be the difference if you used a pinto kmember with his steering rack?
Old 01-24-2006, 08:23 AM
7 Second Club
ty_ty13's Avatar
and do you still get to keep the tilt function of the steering wheel?
Old 01-24-2006, 09:17 AM
LS1Tech Sponsor
MADMAN's Avatar
LS1Tech 20 Year Member
The steering column is the same either way. The pinto set up is similar to mine. The main difference is it doesnt have a steering linkage, or tierods, or bumpsteer kit. All this you will have to fab up. My kit comes with all the parts.
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-24-2006, 02:08 PM
7 Second Club
ty_ty13's Avatar
so i could still use my factory wheel? and yours is a complete bolt-on kit (with a little welding)?
sounds like a very nice piece.
Old 01-24-2006, 02:23 PM
LS1Tech Sponsor
MADMAN's Avatar
Everything in the car is factory.
My rack bolts on to the factory holes and requires one tab to be welded on.
__________________
225-343-9029
Old 01-24-2006, 02:38 PM
7 Second Club
ty_ty13's Avatar
sounds beautiful!
one more thing for me to do while the motor is out
Quick Reply: mad man's rack (no pun)
