9" is in, abs light is on :(
Ok, well i noticed that on my pass. side the connector for the ebrake or abs, which ever one has the spring on its that goes on the hook that opens the ring on the backing plate, well it sticks out the back. when i try to press it in, it knocks out the two bearing that are in the front out. ill get some pics to post so you all can see what im talking about, but if someone already knows, how do i fix it?
