is there a 90 mm maf?
If you are going to stay with a maf sensor, the best one you can use is an unmodified stock sensor.
It will pose no restriction on the pressure side of the system.
If you are making upwards of 500rwhp, the best solution is to ditch the maf alltogether and run 2/3 bar OS by HP tuners, IMHO.
