c-clip retainer
c-clip retainer
i trying to remove my differential but i cant get the retianer for the c clips out. it comes halfway out but hits the gear. is there something im missing? the gears are richmond 4.10's
theres no abs sensors in the rear. the problem is that the block that keeps the axles from sliding in that you remove before you pull the c clips hits the ring gear hwne you try to slide it out heres a picture of it
