Stock 10 bolt the drag radials
Do a search.....Oh, I forgot. The search isn't working. The odds are against you my friend. Some a4 cars with DRs do fine for awhile but the torque shock the T56 puts on the rear is more than it can handle not to mention the added stress due to grippy tires. Start saving for the aftermarket 9" rear. $.02
Originally Posted by red6speedss
What is the cheapest you can find a 12 bolts or a 9in
Cheap and 12 bolt do not go together. I believe the lowest model versions (no abs/traction control) might start around 1800. Fully loaded versions are upwards of 2200-2400.
Originally Posted by 02SSLE
I was wondering if stock 10 bolt with M6 and drag radials will hold up?
Originally Posted by slowpoke96z28
OOOJohn, is your car a daily driver? what backlash is the rear setup at? do you have a stud kit or rear end girdle? what kind of fluid do you use?
I ran a 150 with bfg drag radial on a 01 ws6 6 speed running 11.5 on a bone stock
10 bolt,i did this about 10 times and it never broke. it leaks like a bitch but it does
not make any strange noises or anything. I think i got lucky so i ordered a 12 bolt
strange for next season.
Originally Posted by 2000slpss
mine just went, i didnt even hoo kup really. took a turn and punched and got sideways grabbed second and they went. mine has a ta girdle . heres the aftermath
Originally Posted by LookinAtMyPlate
its really all up in the air. some hold up some dont. 10 bolds are weird
