Band Clamps
Band Clamps
TSP sent two pre formed band clamps for their ORY-pipe to connect to my new pacesetters. I am wanting to buy 3 more to use on the y-pipe its self and I am not sure which ones to buy? Do I buy the 3 inch or what. The y-pipe in 3 inch. I am getting the pre formed ones so that is throwing me off.
Yes, 3 inch. Band clamps are a close 2'nd to actually welding the exhaust together. They also allow you to take off or re-adjust things later on. Don't forget to cut the bolt ends off when your done, that makes for more ground clearence. The drivers side header primary clamp has nowhere to go but down so cut it off while your under there. PM me if you want more info. I just did this not too long ago.
