Those of you with the Delteq ignition
I was wondering if you guys like it? Also, what do you do with your Opti? Do you take it off? I also have a MSD 6-AL box that I assume I would not need if I got this kit. I also have a Crane PS-91 coil on the car as well. Would all that equipment be obsolete? I also would like to know if the Opti has to be in working order to use the kit. Any info would be greatly appreciated.
Yes your opti does need to be in working order. The delteq basicly deletes the single coil/module, cap, rotor and gets replaced with an ignition module and coil setup from a northstar cadillac. There is also a conversion module that takes the place of the stock coil/module.
And yes, I am very happy with it.
