engine overhaul
engine overhaul
Hey guys im trying to get the motor out of my trans-am its a 98, well im trying to disconnect the engine from the bell housing so ive removed all the bolts and lifted up the engine and removed the mounts plus all the other stuff leading up to this point but my transmission wont disconnect from the block so i cant get the engine out is there a special technique for seperating the two? i really need to get the engine out ASAP thanx
they shoudlnt really come out, they are just some small pins that are drove into the bellhousing. i havent had a ls1/4l60e apart, just going by some older small blocks i have seen.
