Transmedic?
Hows 4th gear? Reason I say this is because there is a band that holds in both gears. Something you can check is the 1-2 accumulator piston for cracks. This will cause poor shifts into second or even second gear starts. Kinda sounds like you need a trans. Check out FLT at www.finishlinetrans.com
Good luck!!!
DA WRENCH
Good luck!!!
DA WRENCH
