clutch chatter?
Old 02-13-2006, 08:01 AM
00silver6's Avatar
Default clutch chatter?
what is clutch chatter, and can you hear it?or do you just feel it
Old 02-13-2006, 08:24 AM
calhoon's Avatar
It is the friction "take up" of the clucth application. It is a feel event but you can hear the restults= gear rattle or other NVH things .
Chatter and rattle are a larger concern with aftermarket clutchs because the "tuning "of the center springs is not generally very good( some have no springed stage at all).
Old 02-13-2006, 08:47 AM
00silver6's Avatar
so could it sound like a grind somewhat it does it from a stop in 1st when let the clutch out
Old 02-13-2006, 12:43 PM
calhoon's Avatar
If you mean a rattle noise when you take off in 1st gear , yes thats somewhat normal. It should lesten if you apply the clutch quicker and should not last beyoud a full clutch engagement. As I said before this condition is generally worse with an aftermarket clutch.
Old 02-23-2006, 11:34 AM
kenkaru's Avatar
my spec 3 does a sort of grinding noise if I slip it just right.
It sounds like there may be a large chunk of something in one the friction pucks. It works fine and has been doing it for at least 20k miles so I don't worry about it. It sounds just like a dining room chair sliding on hard wood floor.
Old 02-23-2006, 07:48 PM
SSinisterTX's Avatar
I have a spec III and I got most of the chatter when breakin in but after 2k it was the best clutch I've ever bought and I dropped .3 on my 1/4m
Quick Reply: clutch chatter?
