Replacing Head Gaskets
I'm going to try and finish replacing the head gaskets on the TA. I pulled the drivers side head (but left on) a month ago and pulled all the bolts except one (i couldn't get to) on the passenger side (gave up). I have to jack the motor up to drop the header out of the way to get the last bolt loose.
I'm getting the heads cleaned, inspected, milled. While they are at the machine shop I'm having them put LT4 springs, reatainers, etc. on. As far as cleaning the block surface, what should I use? What should I use to get debri out of the lifter valley and cylinders (vacuum , rag)?
One last thing, does anyone have the part numbers for the oil pressure sender that bolts into the back of the block. I think I might of messed it up while trying to get a wrench back there to get the coolant crossover tube undone.
-Jon
-Jon
take a dremel tool with a cut off wheel and cut the tube running to each head. remove two or three inches and replace with hose and clamps. this makes it easy. ive done five or six cars that way and works great. i usually put a rag in the lifter valley before i clean it. i usually use a piece of snd. paper to clean it with, then wipe it down with super clean on a rag. that should cut any oil residue.
