More ORR questions
More ORR questions
Bill/Boyce,
I have 2 questions about ORR. Regarding licenses the MKM rules say
"The following is recommended in the Grand Touring Division and required for all other Divisions: The Driver must have a valid competition license with the Sports Car Club of America (SCCA)....."
Since I want to run in the 120mph - 140 tech GT2 class, should I get one? I don't think I 'need' one, but where / how would I get one? Does the road course class at PR gain me anything towards this end?
And about harnesses, it says
"Harness Mounting/Age Requirements: Harnesses must be mounted at or on the roll cage, roll bar, frame member, or body panel (with adequate spreader plates).
The shoulder belt mounting height (or roll bar crossover height for floor-mounted shoulder belts) should be no more than 2” +/- from the driver’s shoulder height when seated in a driving position to reduce the possibility of spinal compression injuries. Shoulder harnesses must be secured or stressed over a steel tube at the proper height....."
I think this says it's OK to have the shoulder belts wrapped around the cross bar, like NHRA lets you do. Or do you know if I need to have them attached? Or want them...
Why don't you call up the driving school at PR? I'm pretty sure Don Kitch had a licensing program available local. That said... definitely get some lapping at Portland if you get the chance. That Chicane was a little scary at times.
I killed my ZZ4 bottom end in the 85 vette on that track (drove home knocking with 2-3 psi oil pressure if I revved it at off ramps... LOL). Still had a blast AT the track! Must have good oiling if you can pull some G-s in the corners, though!
Just go take the driving school at PR and you'll be fine. A SCCA license is spendy and takes up a couple of days and really isnt needed. They just reccommend it since it give you more stick time and you learn the limits of the car alot better.
I have mine wrapped wround the horizontal bar and it passed tech. Once you have run the belt through the metal clip, fold it back over and run it over the top and back through. This helps make sure there is no slipage.
You have to keep in mind that this license will get you into events that you watch on TV like the SCCA T1 series. This is where a lot of the great road racers started so they do not take it lightly. You will have an instructor strapped to you the whole time and will come away from there knowing how to drive a car.
See... the license actually costs $100. The balance is for the insurance on the instructor who draws the shortest straw...
Mark, no license is required. Having one will allow you to start in a faster division, but even fully licensed individuals have to work their way up through the classes like everyone else. They simply get to start a little faster. FYI my one day racing school with a few lapping days thrown in + a little begging allowed me to start in a faster division ( 165/130 ) as though I already had my license I'm a good beggar
And having the harness wrapped around the crossbar is an accepted method. I believe they "prefer" that you weld brackets onto the crossbar to mount to, but not "required". Pay particular attention to how your crotch strap is mounted. They get very concerned about this detail.
I did the same thing as Bill. Begged after taking the school. At the SSCC you are forced to take a rookie school your first time out. And from talking with Bill the only thing they were looking for was to make sure you knew where the throttle and the brake were.
LOL isnt that the truth. That kind of how I felt when I went in for my school. I could have sworn I heard Kitch say "OK, who wants the black car with the big roll cage in it and the kid that looks clueless?"
