Question about turbo
Originally Posted by SUPER DAVES Z
you can leave it un-hook. I'd just put a temperary cap or something to keep crap out of it incase you ever decide to use it.
It'll be fine. It's used on some factory turbo cars because some people would never let the turbo cool after a hard run, causing the bearings to coke. As it is with oil cooled only, it would be no different than any standard turbo.
Hey realquick - I have a pair of turbos I want to run that both have water cooled center carts but I dont know how you would run water to them and keep it flowing, or if you need to cool it (aux heat exchanger) or if the radiator might get overwhelmed by the addtion of two hot turbos if you just routed them into the regular cooling system. What were you thinking about as far as that? Or were just going to ditch water cooling? I do know you don't need a turbo timer if you have it...so thats kind of nice.
The amount of heat the turbo(s) put into the cooling system is minimal compared to what is produced by combustion itself. If you have a ball bearing turbo you must hook up the coolant lines, but you can leave them unhooked on a standard journal bearing turbo. I always hook up the lines, they help promote a longer lifespan of your turbo, and will reduce the amount of idle time you need to cool the turbo down after hard driving.
I'm with Eviltwins on this one - IF you do have a true dual ball bearing turbo, I would DEFINATELY hook up the line(s) for the water/coolant. As far as if your turbo is std. journal bearing and it has provisions for it, just remember this: do you unhook your radiator hoses and just let your motor run on oil? I think you'll find the turbo lasts much longer and is more reliable with the extra cooling.
Lo_jack, I was looing a a geat deal ona turbo that had the water cooled center, but I didnt want to run water thru it, so looks like a standard bearing turbo is best for me.
LS1TECH Sponsor
Yes and no...some units can be ran without water some can't. Most of the time you can run them (DBB's) without water as long as your not road racing. EGT's and high oil temps are what hurts turbos. You can typically pull a unit apart and look at the color of heat on the shaft and bearings.
