LT1 is being GAY
I hate to be the first guy to say it, but if it's not the coil it's probably the opti. Had this happen a couple of times on mine. Has it been rainy lately? I know mine would get wet on the inside and I could pull the vent tubes and blow air into it to dry it out and it would fire right up.
If it turns over it isn't the starter.
I'd pull your coil wire, have someone crank it over and see if it's getting spark. If it's not I would suspect a bad coil or a bad ICM. It's possible it's the opti as well, but doing the coil/icm are extremely easy, not very expensive and probably need to be changed anyway.
well the battery is new and its a red top!! and it seems to act up when its raining out .....every other time its fine...when runing its strong and runs great!. the first time it acted up it was raining like hell......but i keeped pumping the gass and fired up and sicn then no promblems...untill last night!!!!!!!
I had a similar problem, it would give me more trouble in the winter though. I got an msd box and it seemed to fix it. I would change the oil though, some gas might have gotten in from repeatedly trying to start it. Good luck
Originally Posted by BlackBirdWs6Zzz
you have ram air i'm guessing from your conversion.......is water gettting in the intake and screwing with it?
As i always say.......more flow, more go!
ok that sounds good. Let us know cuz it's puzzling the hellout of me.
I want to do a 02' body conversion
well i did most of the work but i payed for some dumb *** to wirer the head lights.....the parts i have r from a parts car.....i think u could get all the parts u need for under $2000 + u can sell all ur old parts and make about 1500 off of them so its not to much.....head lights r going to cost u.....but check ebay u can get some good deals...fenders r like 250 new but use they can be 100-200 and hoods well u would have to get a aftermarket one to save some money..front bumper new/used 250-375..
