What to scan with Autotap???
OK, I have LS-1 Edit and AutoTap. What are the most important parameters I should scan to start tracking my fuel, timing, and anything esle that is on tghe important list. I installed a NX Wet kit and want to be sure all is ok.
Thanks,
Thanks,
Re: What to scan with Autotap???
Here is what I would log.
LTerm Bank 1
LTerm Bank 2
Engine Speed
Vehicle Speed
MAF Air Flow Rate
MAF Frequency
Throttle Position Angle
O2 Sensor B1
O2 Sensor B2
Injector Pulse B1
Injector Pulse B2
Ignition Timing Advance
Knock Retard
Engine Coolant Temp
Intake Air Temp
IAC Motor Pintle Position
Fuel Trim Cell
MAP
Good Luck,
Kevin
LTerm Bank 1
LTerm Bank 2
Engine Speed
Vehicle Speed
MAF Air Flow Rate
MAF Frequency
O2 Sensor B1
O2 Sensor B2
Injector Pulse B1
Injector Pulse B2
Knock Retard
Engine Coolant Temp
Intake Air Temp
Fuel Trim Cell
MAP
Good Luck,
Kevin
