K&N Sealing!!!
K&N Sealing!!!
Is it necessary to use the foam gasket that comes with the filter. I put it on my stock lid but now I am getting an aftermarket lid. Is there anywhere I can purchase a new gasket. Thanks a lot.
Yes, You need that gasket for it to seal properly. When you get an aftermarket lid, you will still need that seal (my SLP lid fit the filter the same and I imagine that the others do as well).
If you do not want to shell out for the 'real' seal/gasket, You can find some adhesive backed weather stripping @ the same size all day long at the home depot or lowes... CHEAP! I found stuf that was identical for a few bucks.
Good luck with your project.
I called K&N and told them I had bought a filter and that I needed a new gasket because I had bought an aftermarket lid and I asked if I could buy a new gasket. The representative just asked me for my name and address and sent me a new one in about 5 days for free.
