PCM codes without scanner tool
Does the LS1 2000 PCM output the codes in any way without the use of a scanner tool. My 91 corvette used to send out a specific flash sequence to the check engine light. Like 2 flashes and then a delay then 4 flashes, would indicate a code 24.
