2004r
Old 02-27-2006, 11:29 AM
blown2kss's Avatar
Default 2004r
any body know of any shops that can build one of these to be bullet proof. I need one that can take 1000hp on nitrous.
Old 02-27-2006, 11:25 PM
Restricted User
Automatics's Avatar
Be prepared to spend "BIG" money when you do this. Try Bruce Toole at Performance Transmissions in Sacramento, California.
Old 02-27-2006, 11:39 PM
White2000TA's Avatar
Try Century Transmissions. Mike over there is awesome!!! Im putting one in my car this week.
Old 02-28-2006, 06:32 AM
FLT
FLT's Avatar
IMO there is no 200-4R that is going to take a 1000hp and be bullet proof. Nothing is bullet proof, but a 4l80e would be a good choice. It will hold up to you horse power!! Check out www.finishlinetrans.com they have a level 5 they put in parish8's 5000lb truck that really takes a beating. FLT/PARISH
Old 02-28-2006, 02:09 PM
blown2kss's Avatar
hey pro built do you have a link for performance transmissions, or possibly a number.
thanks.
Old 03-01-2006, 04:59 PM
blown2kss's Avatar
does anyone run with either this trans or the 700R4. If so how has the trans held up.
Old 03-01-2006, 05:23 PM
cablebandit's Avatar
700/4l60e wont hold that...neither will a 200r4...you need a 4l80e
Old 03-02-2006, 09:43 AM
blown2kss's Avatar
problem is that the 4l80e won't fit in a c5. I have been trying to find out what my options are. The more input from people the better.
thanks
Old 03-02-2006, 01:26 PM
Call Yank, he is a sponsor here....I was told he has almost got a 4l80e in a c5 prob SOLVED
Old 03-02-2006, 02:44 PM
Yank's Avatar
Yes, we have a TH400 kit
and the 4L80-E will be ready in 7 day's for the C-5 /C-6 cars
Old 03-02-2006, 03:59 PM
blown2kss's Avatar
that is some good news. how much heavier is the 4l80-e than the 4l60e. How much more power does it rob.
Old 03-02-2006, 04:59 PM
Yank's Avatar
The 4L80-e is about 26 lbs more installed in the C-5, as it has a special light weight converter. and it will use up 10 HP more in overdrive
takes about the same power in 3th gear
But the weak link 4L60-e won't haunt you anymore
Old 03-03-2006, 01:19 PM
blown2kss's Avatar
since this trans is electroniclly controlled is there any way to control all shifts manually.
Old 03-03-2006, 02:14 PM
Yank's Avatar
you can use a control box that has an option for push button shifting
or a full man. valve body
Old 03-03-2006, 03:04 PM
blown2kss's Avatar
from what I hear that trans setup is going to be very expensive. I talked to a tech today and said that the th400 with overdrive and the 4l80e kits are both around $15,000.
Old 03-03-2006, 03:14 PM
Yank's Avatar
you can e-mail me for the correct pricing and info on the kits
