Cats on METH
Cats on METH
Has anyone had problems using meth with your cats. Ran across a thread a while back where in one case. 1st time the user sprayed-injected, the meth caused a cat to fail-fall apart. Not sure if this was due to a poor tunning issue, or setup?
Currently running high flow cats, I guess if I were to have problems it would give me a reason to pull them out. or at least gut them.
FWIW, when I got my car back from getting my STS kit, the cats came apart the very next day. However, it wasnt because of spraying meth since I was still only on the stock 5psi. Wasnt the tune's fault either. At any rate, gutting the cats took me from 396 to 424hp. I havent seen much on here about anyone else having problems with their cats disintegrating so maybe I just had a bad batch? I wouldnt worry too much about it if I were you.
