Lugs and Nuts Questions.
Ok so ive got some 15x3.5 and 15x8 prostars coming. I just started to grind the brakes down and it is coming along great, im now thinkin about what lugs and nuts to use. Here are my requirements thought, i need them to be short enough to be used on the 16x8 stock wheels with the center caps on. And they need to be short enought to look good on the prostars. Any suggestions?
I tried searching on here but I couldn't come up with anything. Those sound right but I can't think of what the right thread size is right now. Not sure about the zinc plating. Mine were chrome Summit brand, and Weld brand. The Weld lugnuts rust easily. BTW you only need open-ended if you're running longer studs.
LS1TECH Sponsor
if you still have stock studs its 12mx1.5 the shank size at .750 should be good i believe though. you do defiently have to run shank nuts though the prostars are not hub centrick like stock wheels are they are lug centrink and center the wheel that way.
So these would work fine
SUM-7540083
Lug Nuts, Flat Seat with Shank, 1/ 2 in. x 20 RH, .750 in. Shank Length, Closed End, Steel, Chrome, Set of 4
Or should i go 7/16
SUM-7540082
Lug Nuts, Flat Seat with Shank, 7/ 16 in. x 20 RH, .750 in. Shank Length, Closed End, Steel, Chrome, Set of 4
Any other suggestions?
SUM-7540083
Or should i go 7/16
SUM-7540082
