knock sensor circuit
what do you guys think about this circuit,
do you think this will work, or will it hurt?
the formula is; resister #1 - kn.sensor / 4,
resister #2 - kn.sensor x 2
Knock Sensor Desensitizing
The 4th gen f-body is prone to timing retardation due to false knock. If you suspect false knock is robbing you of power, you can desensitize your knock sensor with this circuit
http://www.kyfbodies.org/
to see the pic. of the circuit, click the
website, and go to techfiles.
sorry my computer freaked out and i could not
paste the pic. here.
<small>[ April 13, 2003, 12:01 PM: Message edited by: cueball ]</small>
Re: knock sensor circuit
I believe Nineball, who like me suffered from tons of KR, addressed this a long time ago. He came up with a knock sensor desensitizer circuit a long time ago.
sorry about that i did not know this has already
been addressed, i just singed on to this website
in march.
i would like the circuit info. if it is diffirent
than the one i posted.
how did the circuit work?
thanx!
in march.
thanx!
single digit dreamer
i have been told that this wont work and will set codes but it is what i did several months ago and couldn't be happier.
i put 1 10kohm risistor inline with each knock sensor wire. i have seen no codes and my false knock problems are gone. here is a brief history of what i have seen.
stock knock sensor circuit with 6psi whipple>>knock every time i floored it especialy out of the hole and at the shifts.
10k resistor in each circuit with 6psi whipple>> 0 knock
10k resistor in each circuit with 8psi whipple>>full 8deg of knock retard continuas
10k resestor in each circuit with 8psi whipple and 100octane>>0 knock
10k resistor in each circuit with 11psi whipple and 100octane>>4-6deg of KR at the launch tapering thru the run.
all that leads me to believe that my knock sensors are working properly with the 10k resistors.
<small>[ April 15, 2003, 10:44 PM: Message edited by: parish8 ]</small>
