trans swap (m6 to a4)
Re: trans swap (m6 to a4)
You just need to find a PCM file from a 2000 A4 that has the same Segment 1 ID as your car. Then just load it into the PCM, and as long as you have the wiring done right, you're in business.
If I swap from my current m6 to an a4 in my 00 z28 will my edit still work with the auto trans? I see teh auto parameters in edit. will the trans plug in and the ecu be able to pick it up??
Thanks
Sean
Thanks
Sean
