What "skinny" tires are you guys using?
Old 03-07-2006, 08:45 AM
SprayedLT1's Avatar
Default What "skinny" tires are you guys using?
I got some 3.5" drag lites for my car, but the tires that are on there are too tall. They are 28x7.5x15. My friend has a pair or cheapo Futura 165R15s that he wants to sell to me, but he said they are only like 24" tall. My car is lowered a bit and I think that would be too short for ground clearance.
What brand of tire and size are all you guys with skinnys using?
Old 03-07-2006, 02:09 PM
slvrhwk's Avatar
are you going to drive them alot?
If so
Kuhmo 165/80/15 you can get them for $30ea new & I think they are 25.x tall
If not
et front runners you can get them in just about any size.
I had 26" ones on mine in the attached picture.
Hope this helps
Old 03-07-2006, 05:09 PM
SprayedLT1's Avatar
Thanks man. I will not do a lot of street driving with them, mostly track and cruise night type of stuff, but they will be on the street some.
I have a guy that wants to trade my Sportsmans for a pair of 26x7.5x15's, but I'm not sure I want to use them on the street. I may check out those Kumhos.
Old 03-08-2006, 10:38 AM
Studytime's Avatar
How does the weight compare with the Kumho tires?
Ben T.
Old 03-08-2006, 10:52 AM
1_Bad_LS1's Avatar
You want to go with a tire that is designed for a 3 1/2" wheel... I have been doing alot of research on this myself, as I am about to get some front runners myself...
The 165/R15's are actually made for a 5" or so wheel... and they actually press to hard on the 3.5" wheel and could cause excess straa on the wheel causing it to fail...
Your best bet, is to order a set of either Mickey Thompson E/T Fronts or Moroso DS2's in a 26x4.5x15... A little more expensive, but it will weigh less, be safer, and get you down the track quicker...
Old 03-08-2006, 03:32 PM
hashtagBMW
Speed Density's Avatar
Ive got 165 MT sportsmans on my 15x3.5 Prostars.
Old 03-08-2006, 07:30 PM
Krab's Avatar
MT sportman fronts on my 15x4 Bogarts. A little pricey, but they are rated for the weight of our cars and don't cause a light in the gauge cluster to turn on (ABS inop?).
Old 03-08-2006, 07:50 PM
LS69TA's Avatar
I had the 165R15 Kuhmos on 3.5" Prostars. No problems, and damn cheap.
Old 03-10-2006, 08:30 AM
gillbot's Avatar
I used to run 165R15 pep boys tires on my 15x4 convo pros.
Old 03-10-2006, 08:37 AM
LS1TECH Sponsor
badpewter-z's Avatar
im running MT 26x4x15 front runners on mine not reccomended for the street at all though. if you get there sportsmans youll be ine . alot of people will run a 165r15 or 165/80r15 tire just keep an eye on the load ratings and speed ratings
Quick Reply: What "skinny" tires are you guys using?
