Had my true duals put on today..
Old 03-07-2006, 05:22 PM
01 Trans Am's Avatar
Default Had my true duals put on today..
I just wanted some, if any, opinions.. I just had my true duals put on today. I decided to go w/ the SpeedINC x-pipe w/ bullet mufflers. One of the local shops had to fabricate some pieces in order to make this setup fit. I'm a little skeptical as of now... I can't decide whether on keeping this true dual setup or going back to my ory/cb (tsp ory/ magnaflow cb) setup. The reason I say this is because I don't know how well the speedinc x-pipe performs, in other words... i'm afraid of losing hp. I'd rather the true dual setup net me the same amount of rwhp/rwtq or more. Any opinions would help greatly! THANKS!
Old 03-07-2006, 05:34 PM
GM Muscle's Avatar
If it's a nice merge X which I suspect it is, it should out flow the TSP Y.
Old 03-07-2006, 05:37 PM
All right, I hope it is too. Also- Will I need to get another tune since I'm switching setups? Thank you for all the help.
Old 03-07-2006, 05:44 PM
GM Muscle's Avatar
You really don't need a tune for a simple exhaust swap.. More than likely the X pipe set up moved your HP/TQ curves around alittle. You should feel more torque down low and more HP up high over the Y-pipe. It depends how well calibrated your butt dyno is.
Old 03-07-2006, 05:49 PM
hmm, butt dyno? Meaning current dyno? lol
Old 03-07-2006, 06:47 PM
99FormulaM6's Avatar
no, butt dyno....as in get in the car and haul *** and see if it feels like you have more power.lol.
Old 03-07-2006, 07:17 PM
That's what she said...
TheBlurLS1's Avatar
I think i would have asked these questions BEFORE i had the work done!
You should gain power with it over most y-pipe setups. Reason i say MOST is to satisfy all the y-pipe humpers around here!
Anyway, the sound you get from having duals trumps the 1-2hp that you *might* loose, but i doubt you will.
Old 03-07-2006, 07:26 PM
thank you to all, that's all i needed to know. and blur, what is duals trumps? sound? dumped??
Old 03-07-2006, 07:34 PM
FUN LS1's Avatar
Sounds like a good set up (however you got there...); I'd give it a while to get used to it and see how it performs. Get it on a dyno so the next time you make a change you'll know if it was good or bad.
...dang, I should have said "Bad choice; swap back and sell it to me cheap..."
Old 03-07-2006, 08:38 PM
1936FordPU's Avatar
Going from a Y to an X you will need a tune. You are moving alot more exhaust of the heads and it will need more fuel for the extra air going into the chambers to be exhausted.
Old 03-07-2006, 09:59 PM
BigDaddyBry's Avatar
FYI
Butt dyno = SOTP = seat of the pants = being able to feel your car accelerate faster
Trump = (dictionary definition)1. A suit in card games that outranks all other suits for the duration of a hand. Often used in the plural (ie trumps).
So when TheBlurLS1 states that the sound of the true duals trumps a possible 1-2hp loss, he is stating that the sound produced outranks (is better than) a small loss in hp.
Old 03-07-2006, 10:28 PM
nokeman's Avatar
Well put bigdaddy...
Old 03-07-2006, 11:00 PM
Okay, thanks all.... but about the tune I keep getting different answers...?
Old 03-07-2006, 11:03 PM
spazzyfry123's Avatar
Butt-dyno...
Old 03-07-2006, 11:33 PM
TheBlurLS1's Avatar
Come on guys! TRUMP!
Trump can also be used as a verb, like i did.
LS1's trump LT1's......
Never played that cajun *** game Boo-Ray (sp?)? Its the most badass card game in the world! Each hand has whats called "the trump card" whose suit beats all other cards accept for better cards with the same suit.
Old 03-08-2006, 05:34 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It is really not that much to make a tuning difference. I went from y to x and back to y and then x again. There is a seemingly noticeable difference between the 2 but I enjoy the sound of the x pipe and few extra ponies I snagged. Honestly it is worth it IMO to stay X.
Old 03-08-2006, 05:35 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Spades = trump
Old 03-08-2006, 07:59 AM
magius231's Avatar
LS1Tech 10 Year
you don't NEED a tune going to any exhaust system, the computer can compensate for the extra flow reasonably well (thus the reason for O2 sensors!. Thats not to say you won't gain some HP getting it tuned after everything however. There are people running full bolt ons + cam with no tune, although thats really not a good idea
Old 03-08-2006, 11:59 AM
well, i just looked underneath my car and the right hanger is missing. the x pipe is still held up pretty good though. does anyone know where i can purchase one of these? since i have another one of the left side, do i need to replace this one?
Old 03-08-2006, 03:26 PM
tylerdj's Avatar
That would be me If only hptuners wouldn't take a month to get here
