Safe boost for 10.9:1?
Old 03-10-2006, 12:39 AM
mr2guru's Avatar
Default Safe boost for 10.9:1?
Well,
I picked up a maggie GTO kit for just a hair over 2k. And I may put it on this 408. Problem is, I've got -2cc diamonds and 72cc AFR225 heads. So even with a .060 gasket I am looking at 10.9:1 compression.
What kind of boost levels could I safely run on pump 93? 5psi? I would most definately change cams and try to tailor the cam to get a low DCR and no overlap.... any ideas on one of those?
Could this net me 600whp?
I don't know, the price was right and it's something to try. I bet it'd be torquey.
Old 03-10-2006, 02:25 AM
OldBlue's Avatar
I sure as hell wouldn't run much boost at all with a cr that high. Maybe 4-6 pounds with a good fuel system and a safe tune.
Old 03-10-2006, 02:56 AM
mr2guru's Avatar
Yeah that's what I was thinking 4-6psi.... It'll probably be killin' the MP112 blower to make that much boost on a 408 w/ AFR225s and a decent sized cam anyway.
I think finding or having a knowledgeable builder design me a custom cam that takes all this into factor will be the key.
Old 03-10-2006, 08:40 AM
OldBlue's Avatar
I agree that's probably you're best bet....
Old 03-10-2006, 09:45 AM
Nate_Taufer's Avatar
depends on the cam mainly. You could get away with 8-10 lbs if the maggie will make it, which it probably will only make 4-6, on a GOOD tune and the right cam. Youd prob only hit 575 rwhp max with meth inj.
Nate
Old 03-10-2006, 02:13 PM
onefastss223's Avatar
Time for some Alky Injection...
Quick Reply: Safe boost for 10.9:1?
