me sucking at the strip today--video
Old 03-13-2006, 01:01 PM
brickonwheels's Avatar
Default me sucking at the strip today--video
http://videos.streetfire.net/Player....3-71D74C20676C
I felt ok for it being my first pass in a rwd car but i could have done a lot better. notice how the car rolls in the staging. Tranny isnt fully disengaging so i redlighted in one race that didnt get caught on film luckily.[/
Old 03-13-2006, 01:21 PM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
not bad. decent launches ... i say if u practice a bit with reation times and launches u can get 13.5's
good luck next time
Old 03-13-2006, 01:35 PM
good luck next time
I had a 13.5 yesterday. The car has run a 12.5.
Old 03-13-2006, 02:03 PM
93LT1's Avatar
get somre tire ^^
Old 03-14-2006, 12:24 AM
Originally Posted by 93LT1
get somre tire ^^
It has nitto 555 IIs on it, i just cant launch for ****
Old 03-14-2006, 12:47 AM
Mattybz28's Avatar
Slip the clutch, like just pick your foot up as if you're walking and do it from lower rpm's and work your way up.
Old 03-14-2006, 12:56 AM
93LT1's Avatar
no, do a massive burnout instead of the little ones you do. Lower the psi to about 18 or even 15 **** it. You should be able to drop her at 3000 and grab if they are any good. I use mickeytompsons and i can hook em from 2000 if i do a huge burnout.
Old 03-14-2006, 01:22 AM
buffman's Avatar
if that nitto is a street tire (only recal the 555R being a DR) he's prolly not going to gain much if anyhing in a launch by heating up his tires or lowering pressure. While it may benefit some street tires to be slighlty warmed up, most just need a clean burn to clean the crap off the tires.
So in otherwords, get some better tires
Old 03-14-2006, 11:27 AM
mike0035's Avatar
MT drag radials it will hook or bog
Old 03-14-2006, 02:09 PM
ls1charged's Avatar
i think u just need to learn how to launch, thats mainly everyone's problem. mine too.
Old 03-14-2006, 03:17 PM
BlkLT1WS6's Avatar
Get some nitto drags and launch at 4300
Old 03-14-2006, 04:18 PM
slowmofo's Avatar
good looking car!! Better tires and you will hook and/or break your 10 bolt..
Old 03-14-2006, 07:35 PM
93BlackZ's Avatar
there ya go thats a better way to put it. on street tires its just kinda hard to get it to hook.
Old 03-14-2006, 10:06 PM
Chopstix's Avatar
555R = drag radial
555R2 = road race/auto-x tire...same compound, stiffer sidewall
Old 03-14-2006, 10:09 PM
93LT1's Avatar
put a 12 bolt spool rear end in like i did, its AWSOME ;]
Old 03-14-2006, 10:27 PM
Wanna lend me a couple grand?
Old 03-14-2006, 11:53 PM
foggedz's Avatar
Them rims arnt helping eather. Just putting the stock 16s on would probably drop a tenth.
Quick Reply: me sucking at the strip today--video
