Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
How many tires can I refill with a 5gal. portable air tank?
Old 03-25-2006, 01:32 PM
shep28's Avatar
Default How many tires can I refill with a 5gal. portable air tank?
I just bought a five gallon portable air tank. One of my stored cars in a remote location has 4 flats. How many tires will this tank handle before needing a refill? tires are 14s on a mazda 626
Old 03-25-2006, 06:35 PM
indyboom's Avatar
How does a posi trac on a 1969 cuda work??
I dunno .. it just does!
Old 03-25-2006, 06:44 PM
pHEnomIC's Avatar
P1V1 = P2V2
Pressure of tank X vol of tank = Pressure of tires X Volume of tires.
Hope that helps. You can also probably do some fancy stuff with temperature to store even more air in the tank.
No way to tell your answer unless you know how much pressure the air tank will hold and other variables.
Also, keep in mind you cant get all the air out of the tank. unless you have a pump off of the tank, the tire and tank will go to equilibrium when connected.
Old 03-28-2006, 09:54 PM
redbandit98's Avatar
it may inflate two of them, but probably not with the right pressure
Old 03-29-2006, 12:37 PM
yak
yak's Avatar
yeah its just basic thermo however, remember also that pv=nrt so if you cool what is in the tank you will hold more.
Old 03-29-2006, 01:10 PM
lowchevy2go's Avatar
i tried this with flat tires. I was able to get them air'd up but tank only had 100lbs in it and i was able to get one fully to presure 32lbs and the other to about 26 lbs
Old 03-29-2006, 09:59 PM
Diamond Jim's Avatar
Go borrow someones CO2 Paintball tank. Two 20 oz CO2 tanks should fill 4 tires easily, heck one might do it enough to get em rolling.
A lot of off-roaders use CO2 or high pressure (3000+psi) nitrogen bottles. CO2 will expand and tire pressure goes up as they get warmer, so consider it as an emergency use.
The other option is to use a batery operated tire pump. You aren't planning to hike to where the tires are. Are you?
Old 03-29-2006, 10:40 PM
markp03's Avatar
get one of the neat bike pumps with the fold out brackets for your feet and start pumping
Quick Reply: How many tires can I refill with a 5gal. portable air tank?
