Throttle Body Not Wot!!!! Help
Old 03-27-2006, 09:41 PM
djkyle25's Avatar
Default Throttle Body Not Wot!!!! Help
yo wuts up yall, ok well today i was sittin in my car and hit the pedal to the floor( engine not on) and it doesnt like hit the pedal stop, it actually hits the floor first, and when it was all the way to floor my friend was able to still push the accelerator directly on the Throttle body like 1/2 inch more, so i know i need to do some adjusting but where to, cuz it idles right not loose or tite that i can tell, so do i adjust at TB or at pedal (edelbrock TB)
Old 03-27-2006, 09:45 PM
hashtagBMW
Speed Density's Avatar
Tighten the TB cable.
Old 03-27-2006, 09:50 PM
djkyle25's Avatar
but it idles alright would doing that change the idle and would i tighten it at the TB or pedal
Old 03-27-2006, 09:56 PM
hashtagBMW
My bad, i meant tighten the pedal. When i first got my 93 i thought it was fine until I got rides in my friends 94, i decided to take a look at it and there was a lot of slack on the pedal cable under the dash. You might want to look there. I didnt tighten it too much but its now perfect.
Old 03-28-2006, 10:10 AM
slow96z's Avatar
It idles fine because of the idle air controller motor, it really does not have much to do with the throttle cable. If the car has traction control there is an adjustment on the cable behind the throttlebody. I'm not sure how to do it at the petal, never looked at it.
Quick Reply: Throttle Body Not Wot!!!! Help
