cap and rotor seperation
Old Mar 23, 2006 | 06:55 AM
NOTAV6's Avatar
Default cap and rotor seperation
how do i seperate the cap and rotor from the opti do i need some special tools or something and any suggestions im putting a msd cap and rotor on or at least thats the plan i still havent gotten it yet.....
Old Mar 23, 2006 | 08:00 AM
96SCTA's Avatar
There come apart with a weird torqs bit. Dont remember what number it was. I got a set of them from the local parts store. Its a star type tip. Buy the time i got most of mine out they were chewed up . So i just replaced them with some regular screws and bolts. Good luck
Old Mar 23, 2006 | 08:56 AM
redhot lt-1's Avatar
it takes a long or deep torqs i have on go to a local snap-on tool dealer tale them the socket is called an size (e4) alsosome other numberon it is (stle40) you should be able to get the proper socket they run about $30 so guard it with your life when you get it.
Old Mar 23, 2006 | 09:19 AM
slow96z's Avatar
Just take the Opti to Sears hardware and show them the screw. They have the socket there and if I remember correctly it was either $6 or $12. Make sure before you buy it you try it out so you know you have the right one!
Old Mar 23, 2006 | 09:28 AM
01Z28M6's Avatar
You can actually use an appropriate size torx bolt as a reverse socket tool if you can figure out how to hold the bolt by the threads without ruining them. I believe you can borrow the bolt from the throttle body; but as said, you have to protect the threads on the bolt somehow in order to put it back.
Old Mar 23, 2006 | 10:06 AM
NOTAV6's Avatar
ok thanks guys thats what i needed to know i wasnt sure if it was a torqs or not
Old Mar 23, 2006 | 12:56 PM
30th TA 0219's Avatar
just to be a stickler, it's TORX, and it's a trademarked name.
Why you guys don't have a full set of Torx bits in your toolbox is beyond me!
Old Mar 23, 2006 | 01:28 PM
NOTAV6's Avatar
because i have never needed them before
Old Mar 23, 2006 | 01:47 PM
01Z28M6's Avatar
This is not a standard torx, it takes a special tool. The star is male whereas standard torx bolts are female. I have never seen it used on anything else.
Old Mar 23, 2006 | 03:35 PM
slow96z's Avatar
Yeah, I have a pretty substantial supply of tools and I only have 1 reverse torx piece.....
Old Mar 23, 2006 | 04:13 PM
NOTAV6's Avatar
yeah so do we all the tools i have bought all my dads tools that he has accumulated over 50 years and my bro's tools that he has bought and we dont have any reverse torqs, i have standard ones though
Old Mar 23, 2006 | 08:20 PM
whynot's Avatar
I used a small socket like screw driver, fit just right, and never chewed up the screws, and I have used it on many other peoples optis as well.
Old Mar 23, 2006 | 08:27 PM
NOTAV6's Avatar
ill have to try that cause i have some of those also
Old Mar 24, 2006 | 10:27 AM
Smokinlt1's Avatar
It's an e-4 reverse torx bit, I got mine form the Matco man for $10.
Oh yeah, make it's a deep well to make life easier.
Old Mar 26, 2006 | 02:42 PM
Niteninja's Avatar
Same price with Snap-On.
Old Mar 27, 2006 | 11:21 AM
goodol'93z's Avatar
i went to lowes found a bolt that fit pefectly (the head of the bolt in to the opening of the screw),got some pressure pliars to the other side of the bolt and took it off and put the new ones back on the same way no problem dont know if that helps. total cost 18 cents
Old Mar 27, 2006 | 01:41 PM
instead of pliers, how about double nutting it, and turning the 'secured' nut?
Anyone remember what size nut fits in there?
Old Mar 28, 2006 | 09:53 AM
01Z28M6's Avatar
Why you don't have a full set of reverse torx bits in your toolbox is beyond me!
Old Mar 28, 2006 | 10:19 AM
383LT1S10's Avatar
I concur, just because you've never NEEDED a tool is NO reason not to buy one! I have a garage full of stuff I haven't needed more than maybe once
Old Mar 28, 2006 | 10:45 AM
NOTAV6's Avatar
money better spent elsewhere for me im on a poor college school budget all the tools i have i bought when i was active duty making 800 every 2 weeks and didnt have any bills
