Bottle install??
Bottle install??
When installing the bottle, how do you get the feed line to the front of the car and keep it hidden?? Do you drill a hole so the ffed line can go under car??? Anyone who has nitrous please tell me how they routed their feed line to the noids
I routed mine through the car under the carpet, under the passanger side trim, and out the hole behind the PCM. If you go this route, put some wire loom around the braided line once you get close to the fire wall, wouldn't want your feedline rubbing holes in any wires.
