Ram Adjustable Master..what The Hell?
Does anyone have a Ram ADJ. Master CYL. Is it suppose to look like a cheap autozone mastercylinder with an adj. rod welded to it? just wondering if im jipped...
No you're not jipped, that is the correct unit. It is a 02' stock master cylinder with adjustment. Mine has worked great for me!
One other thing that I ran into was I couldn't get the end to fit on the clutch pedal with the retaining clip on. The retaining clip wouldn't fit on because the swivel joint that Ram put on there is too wide. I had to dremel the hell out of the swivel joint so the retaining clip would fit on.
I wrote little review of it a while back btw: https://ls1tech.com/forums/manual-transmission/415347-ram-adjustable-master-cylinder-install.html
I felt the same way you did when I got mine. But It's been a great piece so far. Like above, I had to grind down the rod end to fit on the pedal. I have to say it is real nice to have the adjustability. And for those that have installed theirs, I hate locking washers!!
