is this safe
is this safe
i was thinking about putting a 75 or 100 wet shot on my 99 z28 but it has 140000 miles on the motor but still runs really strong i have had no problems with anything but was wondering if it would hurt anything and still be safe?
You should be okay. You could always do a leakdown test before you sprayed her to see what shape the motor is in. If you wanted to play it very safe maybe upgrade the fuel pump.
Matt
Matt
I agrere that it should be ok if the car has been well taken care of and still has a good leak down and compression test. However that is alot of miles. I would not put nitrous on it unless you are ready to expect the worse. No one can give a for sure answer on that.
Dave
Dave
